[osgeo4w-dev] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
trac_osgeo4w at osgeo.org
Sun Dec 17 12:02:03 PST 2017
Reporter: hellik | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Resolution:
Keywords: las |
Comment (by hellik):
Replying to [comment:7 jef]:
> Replying to [comment:6 hellik]:
> > tried with the OSGEo4W setup here, can't revert back to the earlier
version.
> Now you can.
http://download.osgeo.org/osgeo4w/x86_64/release/laszip/setup.hint
sdesc: "The LASzip compression library"
ldesc: "LASzip is a compression library for ASPRS LAS LiDAR data"
maintainer: hobu
category: Libs Commandline_Utilities
requires: shell msvcrt2015
prev: 2.2.0-3
curr: 3.1.1-3
I've seen that you changed the setup.hint.
IMHO it doesn't solve the fundamental issue regarding compiling/runtime in
all the user's OSGeo4W stack.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
