[osgeo4w-dev] [osgeo4w] #535: Problem with QGIS and gdal 2.2.0-5
trac_osgeo4w at osgeo.org
Mon Jun 19 16:37:56 PDT 2017
Reporter: PedroNGV | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: gdal,qgis,osgeo4w
I've updated today QGIS from OSGeo4W64bits and it updated also gdal to
version 2.2.0-5.
It lead to a constant and inconsistent QGIS crash, sometimes at the start,
other times when openning some saved projects, and other times, with new
projects, when editing data, or simply zooming in and out.
Tested with QGIS 2.18.9-14 and 2.14.15-5, with and without GRASS plugin.
Also starting with --noplugins, I get the crash.
Then I did the downgrade of gdal to 2.2.0-3, and everything seems to work
again.
To confirm, I've installed again gdal 2.2.0-5, tested, and get the crash
right at the QGIS start. Downgraded again to gdal 2.2.0-3 and I get
everything working again.
So, it seems to be something wrong with QGIS and gdal 2.2.0-5.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/535>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
