[osgeo4w-dev] [osgeo4w] #536: QGIS install with OSGeo4W issue
    trac_osgeo4w at osgeo.org
    Tue Jun 27 02:45:57 PDT 2017
Reporter:  Guillaume Huby     |       Owner:  osgeo4w-dev@…
    Type:  defect             |      Status:  new
Priority:  critical           |   Component:  Package
 Version:                     |  Resolution:
Keywords:  QGIS, QGIS-Common  |
Comment (by Guillaume Huby):
 Good idea to have a look at all packages, I found a package named "Gdal
 2.0.1" that was not selected.
 I selected it and proceed to install.
 I had a new error message on qgis-common package (approximate translation
 from french):
 "Entry point of procedure ?mRunningFromBuildDir21810 at QgsApplication@@0_NA
 could not be found in library of dynamic links
 C:\OSGEO4~1\apps\qgis\crssync.exe".
 Yet I could start QGIS but I have an error message:
 "Impossible to load PyQGIS [...]".
 UI starts and displays "QGIS 2.18.7" instead of QGIS 2.18.10.
 I selected (I list only main packages, the list is long):
 * gdal 2.2.0-6;
 * setup OSGeo4W 1.0.7-13;
 * shell OSGeo4W 1.0.1-2;
 * grass 7.2.1-1;
 * grass6 6.4.3-5;
 * qgis 2.18.10-1;
 * saga 2.1.2-2;
 * saga-ltr 2.3.2-1;
 * Many gdal packages with release 2.2.0-6;
 * Many QGIS packages with release 2.18.10-1.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/536#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
