[osgeo4w-dev] [osgeo4w] #524: sqlite3.dll build without -DSQLITE_ENABLE_COLUMN_METADATA
OSGeo4W trac_osgeo4w at osgeo.org
Thu Mar 16 16:25:06 PDT 2017
Reporter:  rouault      |      Owner:  osgeo4w-dev@…
    Type:  enhancement  |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:  sqlite gdal
 GDAL can take advantage of some advanced function of sqlite if the later
 is built with  -DSQLITE_ENABLE_COLUMN_METADATA
 In that case GDAL's nmake.opt must declare SQLITE_HAS_COLUMN_METADATA=yes
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/524>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
