All, A note to let you know that I have been working to get PDAL healthy on OSGeo4W64, and in the process, I have added two additional packages: - libharu http://libharu.org/ for PDF generation - jq https://stedolan.github.io/jq/ for JSON command-line parsing - pdal https://pdal.io Point Data Abstraction Library Howard
