[osgeo4w-dev] [osgeo4w] #531: PATH to WBEM is wrong
trac_osgeo4w at osgeo.org
Fri May 26 20:31:01 PDT 2017
Reporter: tobwen | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Installer
Version: | Keywords: installer, WBEM, path
''%OSGEO4W_ROOT%\bin\o4w_env.bat'' tries to set a clean path variable to:
REM start with clean path
set path=%OSGEO4W_ROOT%\bin;%WINDIR%\system32;%WINDIR%;%WINDIR%\WBem
Actually, the path to ''WBem'' is wrong, the correct one is:
{{{%WINDIR%\system32\wbem}}}
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/531>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
