[osgeo4w-dev] [osgeo4w] #545: the algorithm OGRLayerClassifier (in QGIS 2.18) does not run properly anymore and must be updated/replaced.
trac_osgeo4w at osgeo.org
Thu Nov 23 03:09:02 PST 2017
Reporter: SIGLA | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: blocker | Component: Package
Version: | Keywords: otb OGRLayerClassifier VectorClassifier
After installing the last version of QGIS (2.18.14) provided in OSGeo4W
(windows 64 bits), the algorithm OGRLayerClassifier does not run properly
: the model file cannot be loaded as input file. We can only save or
overwrite the model file. I ask for updating this algorithm so that we can
properly load the model file and save the output file as shape or sqlite
format. Another solution would be to replace this outdated algorithm by
the newer provided from OTB 6.0. The new algorithm VectorClassifier works
fine in the standalone app and should be added to XML descriptors of QGIS.
For this purpose, OSGeo4W must be updated like OSGeo Live for linux
systems which provide OTB 6.0 now.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/545>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
