[osgeo4w-dev] Upcoming PROJ 5.0.0 release
Jürgen E. Fischer
jef at norbit.de
Mon Feb 19 07:49:21 PST 2018
Hi Kristian,
On Mon, 19. Feb 2018 at 14:52:16 +0000, Kristian Evers wrote:
> As you may know, a new version of the PROJ library is about to be released.
> At the moment we are on release candidate 3 [0]. It is very likely that this
> release candidate will be promoted to the final release. Before that happens
> though, I want to make sure that everything works as expected in OSGeo4W. I
> still haven't received any feedback on the release candidates from Windows
> users though. Could someone please test that the release candidate builds and
> works as expected in the OSGeo4W environment?
5.0.3RC3-1 is packaged for testing. Seems to work as a drop in replacement of
4.9.3. Should there be ABI incompabilities?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20180219/eac203f0/attachment.sig>
More information about the osgeo4w-dev
