[osgeo4w-dev] QGIS3: packages & versioning
Jürgen E. Fischer jef at norbit.de
Wed Feb 28 14:24:11 PST 2018
Hi Tobias,
On Wed, 28. Feb 2018 at 23:11:26 +0100, Tobias Wendorff wrote:
> Am Mi, 28.02.2018, 22:56 schrieb Jürgen E. Fischer:
> > Don't think so. But why should I?  What's so interesting about the version
> > numbers?
> Well, I don't think I need to explain the need of versioning ;)
Just your need for a different versioning.  I don't see any.
> So, some day, there might be stable qgis 3.0.3-17 and nightly 3.0-128 ?
No.  As said the nightly has the same (upstream) version number.  So when 3.0.3
is released both qgis and qgis-rel-dev will switch to 3.0.3-1.  If there's not
need for packaging fixes qgis will stay at 3.0.3-1 until the next point
release, while qgis-rel-dev will increase to something like 3.0.3-30 by the
next point release, when both switch to 3.0.4-1.
3.0-x doesn't exists except for the meta packages - and that just because the
dependencies probably won't change with point releases anyway.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20180228/6f2a42bf/attachment.sig>
More information about the osgeo4w-dev mailing list
