[osgeo4w-dev] [osgeo4w] #550: OSGeo4W-64 bit: lasinfo crashes with an entry point not found
    trac_osgeo4w at osgeo.org
    Sat Jan 20 11:25:49 PST 2018
Reporter:  hellik    |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:            |  Resolution:
Keywords:  las       |
Comment (by hellik):
 Replying to [comment:10 martinl]:
 > I took liberty to create the new `laszip2` package (1) and updated
 liblas setup.hint for new laszip2 dependency.
 thanks for the work around
 >I did these changes only for x64_64. So we can finally re-enable liblas
 support in GRASS.
 yes
 > It would be better if we could force version dependency in liblas
 setup.hint file. To my knowledge it's not possible, right?
 > Let me know if laszip2 package as workaround is OK for you. Then I would
 ask @hobu to remove laszip v2 packages from laszip directory (I don't have
 rights to do it).
 > (1) http://download.osgeo.org/osgeo4w/x86_64/release/laszip2/
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/550#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
