[osgeo4w-dev] [osgeo4w] #574: gdalbuildvrt fails handling wildcards under Win1 1803
trac_osgeo4w at osgeo.org
Fri Jun 15 10:26:22 PDT 2018
Reporter: Langlaeufer | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: GDAL,
After Spring update of Windows 10 (to r1803) gdalbuildvrt fails to handle
wildcards.
Behavior.
computer 1: Programm is running without messages, no output is generated.
computer 2: programm is running, showing error "missing file", result is
generated but the first file of each folder is missing. The filename of
the missing file was only 1 character from the filename of the missed
file. It seams that a inclomplete string was created by processing the
wildcard.
affected version. GDAL comming with QGIS 3.0.x packagees
it is not a GDAL bug. GISInternals x64 MSVC17 build of GDAL don't show
this problem.
I guess the library used for building GDAL binaries is not compatible with
current version of windows 10.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/574>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
