[osgeo4w-dev] [osgeo4w] #570: pip3
trac_osgeo4w at osgeo.org
Wed Sep 5 13:12:01 PDT 2018
#570: pip3
Reporter: rduivenvoorde | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: |
Comment (by hellik):
Replying to [comment:13 hellik]:
> tested here:
> run o-help for a list of available commands
> C:\>call py3_env.bat
> C:\>SET PYTHONPATH=
> C:\>SET PYTHONHOME=C:\OSGEO4~1\apps\Python36
> C:\>PATH
C:\OSGEO4~1\apps\Python36;C:\OSGEO4~1\apps\Python36\Scripts;{app};C:\OSGEO4~1\apps\Python27\Scripts;C:\OSGEO4~1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem;C:\OSGEO4~1\apps\msys\bin;C:\Program
Files\R\R-3.4.4\bin\x64
> C:\>pip3
> Fatal error in launcher: Unable to create process using '"'
> C:\>
> ckecked in the OSGeo4W installer wizard, pip3 isn't installed.
now installed pip3 via the OSGeo4W-installation wizard:
C:\>SET PYTHONPATH=
C:\>PATH
C:\>pip3
Usage:
pip3 <command> [options]
Commands:
install Install packages.
download Download packages.
uninstall Uninstall packages.
freeze Output installed packages in requirements
format.
list List installed packages.
show Show information about installed packages.
check Verify installed packages have compatible
dependencies.
config Manage local and global configuration.
search Search PyPI for packages.
wheel Build wheels from your requirements.
hash Compute hashes of package archives.
completion A helper command used for command
completion.
help Show help for commands.
General Options:
-h, --help Show help.
--isolated Run pip in an isolated mode, ignoring
environment variables and user configuration.
-v, --verbose Give more output. Option is additive, and
can be used up to 3 times.
-V, --version Show version and exit.
-q, --quiet Give less output. Option is additive, and
can be used up to 3 times (corresponding to
WARNING, ERROR, and CRITICAL logging
levels).
--log <path> Path to a verbose appending log.
--proxy <proxy> Specify a proxy in the form
[user:passwd@]proxy.server:port.
--retries <retries> Maximum number of retries each connection
should attempt (default 5 times).
--timeout <sec> Set the socket timeout (default 15 seconds).
--exists-action <action> Default action when a path already exists:
(s)witch, (i)gnore, (w)ipe, (b)ackup,
(a)bort).
--trusted-host <hostname> Mark this host as trusted, even though it
does not have valid or any HTTPS.
--cert <path> Path to alternate CA bundle.
--client-cert <path> Path to SSL client certificate, a single
file containing the private key and the
certificate in PEM format.
--cache-dir <dir> Store the cache data in <dir>.
--no-cache-dir Disable the cache.
--disable-pip-version-check
Don't periodically check PyPI to determine
whether a new version of pip is available for
download. Implied with --no-index.
--no-color Suppress colored output
it works as expected
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/570#comment:16>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
