[osgeo4w-dev] [osgeo4w] #588: gdal_merge.bat Runtime Error. QGIS 3.4.3 Standalone Installers for 32 and 64 bit Windows systems (was: gdal_merge.bat Runtime Error. QGIS 3.4.3 Standallone Installers for 32 and 64 bit Windows systems)
trac_osgeo4w at osgeo.org
Tue Jan 8 07:10:17 PST 2019
Reporter: gabrieldeluca | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: qgis-3 gdal-merge numpy |
Description changed by jef:
Old description:
> On clean installs of the QGIS 3.4.3 Standallone Installers for 32 and 64
> bit builds for Windows systems, the ''GDAL Merge'' tool produces images
> with only zero values in all pixels when the result is saved to a
> temporary file (if not, the merged file is well generated but the command
> output is the same).
> Log:
> Processing algorithm…
> Algorithm 'Merge' starting…
> Input parameters:
> { 'DATA_TYPE' : 5, 'INPUT' :
> ['D:/test/merge/S44E170.hgt','D:/test/merge/S44E171.hgt'], 'NODATA_INPUT'
> : None, 'NODATA_OUTPUT' : None, 'OPTIONS' : '', 'OUTPUT' :
> 'C:/Users/Gabriel/AppData/Local/Temp/processing_6e5c1804cb924bf882b2ccc82074d4cc/3b8fd4e987774e5fb55ea11a62d9420c/OUTPUT.tif',
> 'PCT' : False, 'SEPARATE' : False }
> GDAL command:
> cmd.exe /C gdal_merge.bat -ot Float32 -of GTiff -o
> --optfile
> C:/Users/Gabriel/AppData/Local/Temp/processing_6e5c1804cb924bf882b2ccc82074d4cc\mergeInputFiles.txt
> GDAL command output:
> 0RuntimeError: module compiled against API version 0xc but this version
> of numpy is 0xa
> Traceback (most recent call last):
> File "C:\PROGRA~1\QGIS3~1.4\bin\gdal_merge.py", line 611, in <module>
> sys.exit(main())
> File "C:\PROGRA~1\QGIS3~1.4\bin\gdal_merge.py", line 596, in main
> fi.copy_into(t_fh, band, band, nodata)
> File "C:\PROGRA~1\QGIS3~1.4\bin\gdal_merge.py", line 343, in copy_into
> nodata_arg)
> File "C:\PROGRA~1\QGIS3~1.4\bin\gdal_merge.py", line 124, in raster_copy
> m_band)
> File "C:\PROGRA~1\QGIS3~1.4\bin\gdal_merge.py", line 180, in
> raster_copy_with_mask
> t_xsize, t_ysize)
> File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\site-
> packages\osgeo\gdal.py", line 2635, in ReadAsArray
> from osgeo import gdalnumeric
> packages\osgeo\gdalnumeric.py", line 2, in <module>
> from osgeo.gdal_array import *
> packages\osgeo\gdal_array.py", line 17, in <module>
> _gdal_array = swig_import_helper()
> packages\osgeo\gdal_array.py", line 16, in swig_import_helper
> return importlib.import_module('_gdal_array')
> File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\importlib\__init__.py",
> line 37, in import_module
> __import__(name)
> ImportError: No module named _gdal_array
> Execution completed in 1.81 seconds
> Results:
> {'OUTPUT': <QgsProcessingOutputLayerDefinition
> {'sink':C:/Users/Gabriel/AppData/Local/Temp/processing_6e5c1804cb924bf882b2ccc82074d4cc/3b8fd4e987774e5fb55ea11a62d9420c/OUTPUT.tif,
> 'createOptions': {'fileEncoding': 'System'}}>}
> Loading resulting layers
> Algorithm 'Merge' finished
> Manually solved from the ''OSGeo4W.bat'' (as Administrator) shell:
> C:\Windows\System32>python -m pip install -U numpy
> Collecting numpy
> Using cached
> https://files.pythonhosted.org/packages/74/a4/1bae5948ac37ee6769ffdf01fef3e1c731981574d4d416e2876070441688/numpy-1.15.4-cp27
> -none-win_amd64.whl
> Installing collected packages: numpy
> Found existing installation: numpy 1.12.1+mkl
> Uninstalling numpy-1.12.1+mkl:
> Successfully uninstalled numpy-1.12.1+mkl
> Successfully installed numpy-1.15.4
> After that, ''Merge'' tool works fine and without error logs.
> Tested with the builds:
> [http://download.osgeo.org/qgis/windows/QGIS-
> OSGeo4W-3.4.3-1-Setup-x86.exe]
> [http://download.osgeo.org/qgis/windows/QGIS-OSGeo4W-3.4.3-1-Setup-
> x86_64.exe]
> in Windows 7 and Windows 10, with the following data:
> [https://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Islands/S44E170.hgt.zip]
> [https://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Islands/S44E171.hgt.zip]
> Reports found:
> [https://gis.stackexchange.com/questions/307195/getting-black-square-
> after-merging-two-rasters-in-qgis/307284#307284]
> [https://issues.qgis.org/issues/20895]
New description:
Input parameters:
GDAL command:
--optfile
0RuntimeError: module compiled against API version 0xc but this version of
numpy is 0xa
sys.exit(main())
nodata_arg)
m_band)
t_xsize, t_ysize)
File "C:\PROGRA~1\QGIS3~1.4\apps\Python27\lib\importlib\__init__.py", line
__import__(name)
Results:
Collecting numpy
Using cached
-none-win_amd64.whl
x86_64.exe]
Reports found:
after-merging-two-rasters-in-qgis SE Getting black square after merging
two rasters in QGIS ]
[https://issues.qgis.org/issues/20895 QGIS #20835]
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/588#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
