[osgeo4w-dev] qgis2.18 in osgeo4w plan
Jürgen E. Fischer
jef at norbit.de
Fri Jan 18 06:46:21 PST 2019
Hi Martin,
On Fri, 18. Jan 2019 at 15:32:17 +0100, Martin Landa wrote:
> I would like to ask if there is any plan to provide qgis2.18 package in
> osgeo4w framework after qgis3.4 become LTR. In Feb 22 [1], if I understand
> well become:
> * qgis-ltr -> 3.4
> * qgis -> 3.6
> The question is whether there is any plan to provide after this change also
> qgis2.18 package, eg. `qgis2`. In this case I could prepare special grass
> package compatible with qgis2, eg. grass-qgis2.
I don't have plans for that. Who want's to use 2.18 after it's EOL can still
install from the standalones.
> The is also question which GRASS version will be used for qgis2.18.28
> packaging.
The currently available one.
> 2.18 seems to be prepared for GRASS 7.6.0 [2], I am not sure if tested. I
> would leave decision on QGIS packager whether to use GRASS 7.4.4 or GRASS
> 7.6.0.
> Please just inform me when I can move 7.6.0 version from `test` to `curr`.
Updating it sometime before a qgis point release would be better - I'd stay
with 7.4 for now. So there is a chance that it can at least be tested with
some nightlies before the release.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20190118/78f433fe/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20190118/78f433fe/attachment.ksh>
More information about the osgeo4w-dev
