[osgeo4w-dev] [osgeo4w] #599: gdal204.dll not loading win10 amd64 python 3.7.1, django 2.1.7
trac_osgeo4w at osgeo.org
Sun Mar 17 08:30:00 PDT 2019
Reporter: rhaimann | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords: OSGeo4W, gdal204, WinError, Django,
| Python
Loaded OSGeo4W64 on Windows 10 AMD 64 machine running Python 3.7.1 Django
2.1.7. Could not load gdal204.dll. The file name was being read correctly.
Updated lib_names in lidgdal.py to include gdal204 and gdal203 ( lib_names
= ['gdal204','gdal203','gdal202', 'gdal201', 'gdal20', 'gdal111',
'gdal110', 'gdal19']). In settings.py set GDAL_LIBRARY_PATH to point to
the full path for gdal204. Put in a print statements in __init__.py for
self.__name, the path and filename were being read. Python kept throwing
an error, from the Windows OS either WinError 126 or WinError 127
depending on how I had the paths set up. Put in an entirely fresh virtual
environment. Deleted earlier versions of Python before doing so. Same
errors kept being thrown.
Changed the GDAL_LIBRARY_PATH to point to gdal111 that was included in the
install. This stopped throwing the error so the Django server would start.
There seems to be some issue with the compile of gdal204.dll. While the
file is read, internal functions seem to be not finding something that is
being called. No further detail is provided in the error message. Rather
than recompiling the source under MS C++ 2017, going to move forward with
gdal111.dll for now. Not entirely sure what the issue is.
Hope this helps.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/599>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
