[osgeo4w-dev] WinGRASS build up (WIP)
Helmut Kudrnovsky
hellik at web.de
Tue Nov 5 11:31:36 PST 2019
Hi Jürgen,
>Or just build GRASS with the "test" packages, upload it and then we can remove
>all the "experimental" tags.
just checked OSGeo4W, to be sure:
OSGeo4W normal mode
GDAL 2.4.1-1
PROJ 5.2.0-1
GEOS 3.8.0-1
OSGeo4W testing/experimental mode, update would be
GDAL 2.4.1-1 => GDAL 3.0.2-1
PROJ 5.2.0-1 => PROJ 6.2.1-1
GEOS 3.8.0-1
I could do a test compilation with OSGeo4W testing/experimental mode and issue a
grass-7.8.1RC1-2.tar.bz2
with test in setup.hint.
not sure how ready Martin's build environment is to switch also to build addons ?!
regards
Helmut
Gesendet: Dienstag, 05. November 2019 um 18:56 Uhr
Von: "Jürgen E. Fischer"
Betreff: Re: Re: WinGRASS build up (WIP)
Hi Helmut,
On Tue, 05. Nov 2019 at 18:30:18 +0100, Helmut Kudrnovsky wrote:
> >Any idea when GRASS will be updated with the new dependencies?
> see https://github.com/OSGeo/grass/pull/136#issuecomment-547497328
> "Sure it is still GDAL2"
> is OSGeo4W still default in gdal2/proj5? is gdal3/proj6 still in OSGeo4W experimental/testing?
I went ahead an did all what is proposed there and now you can build GRASS with
GDAL3 and PROJ6 using the "experimental" packages. Once that's done we can
flip the switch and take all the "experimental" packages live - they are only
waiting for GRASS.
> in #136, environment is pointing to gdal-dev proj-dev, which I assume is gdal3/proj6, right?
No, GDAL master (3.1 2b) and PROJ master (7.0 2b). And #136 is for master
(ie. grass-daily)
#137 was for the release branch and was merged.
> GRASS is in a RC cycle for GRASS 7.8.1: RC1
With #118 merged - so it should already work with GDAL3 and PROJ6.
> a possible workflow may be (?):
> (1) update/adapt #136 to reflect a default gdal3/proj6 in OSGeo4W
> (2) apply updated PR to issue a GRASS 7.8.1 RC2
> (3) switch OSGeo4W to a default gdal3/proj6
> (4) binary release GRASS 7.8.1 RC2 in OSGeo4W
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de[https://www.norbit.de]
QGIS release manager (PSC) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Juergen Fischer, Nils Kutscher HR: Amtsgericht Aurich HRB 100827
Datenschutzerklaerung: https://www.norbit.de/83/[https://www.norbit.de/83/]
More information about the osgeo4w-dev
