[osgeo4w-dev] WinGRASS build up (WIP)
Helmut Kudrnovsky hellik at web.de
Wed Nov 6 00:42:40 PST 2019
>next daily builds (32/64bit) should be built against GDAL3/PROJ6.
daily build 78:
https://wingrass.fsv.cvut.cz/grass78/x86_64/logs/log-r9c8923eb9-9/package.log
checking for location of External PROJ includes... /c/OSGeo4W64/include
checking for proj.h... yes
checking External PROJ major version... 6
checking External PROJ minor version... 2
checking External PROJ patch version... 1
found PROJ version 6.2.1
using new PROJ version 5+ API
checking for location of External PROJ library... /usr/src/grass78/mswindows/osgeo4w/lib
checking for proj_pj_info in -lproj... yes
checking for location of External PROJ data files... /c/OSGeo4W64/share/proj
checking for /c/OSGeo4W64/share/proj/epsg... no
configure: warning: *** Unable to locate PROJ data files.
GDAL support:               yes
daily build 79:
https://wingrass.fsv.cvut.cz/grass79/x86_64/logs/log-r39af5f541-9/package.log
checking for location of External PROJ library... /usr/src/grass79/mswindows/osgeo4w/lib
GDAL support:               yes
daily builds with proj6/gdal3 in OSGeo4W looks good so far.
regards
Helmut
More information about the osgeo4w-dev mailing list
