[osgeo4w-dev] [osgeo4w] #598: Fiona can't be imported into python37, DLL error
trac_osgeo4w at osgeo.org
Tue Sep 17 03:04:43 PDT 2019
Reporter: Andreas Müller | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: python3 fiona geopandas gdal |
Comment (by Andreas Müller):
I came across this issue again and now tried both osgeo4w64 and
osgeo4w(32). I installed fiona along with gdal203 "et voila": It works
with the 64-bit version but fails with 32-bit one.
This is the error i got in the python shell:
>>> import fiona
File "<stdin>", line 1, in <module>
File "C:\OSGeo4W\apps\Python37\lib\site-packages\fiona\__init__.py",
line 87, in <module>
from fiona.collection import BytesCollection, Collection
File "C:\OSGeo4W\apps\Python37\lib\site-packages\fiona\collection.py",
line 9, in <module>
from fiona.ogrext import Iterator, ItemsIterator, KeysIterator
ImportError: DLL load failed: Das angegebene Modul wurde nicht gefunden.
Also it would be nice, if gdal203dll would be in "requires" of fiona.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/598#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
