[osgeo4w-dev] [QGIS-Developer] OSGeo4W: python libraries missing when installing plugins
Jürgen E. Fischer
jef at norbit.de
Fri Sep 20 11:31:21 PDT 2019
Hi Calvin,
On Fri, 20. Sep 2019 at 13:28:05 -0400, C Hamilton wrote:
> I personally feel that the libraries you mentioned ( Numpy, SciPy) should
> always be installed without having to specifically request them.
numpy is a dependency of python3-gdal which is a dependency of qgis - so that's
always installed anyway.
SciPy is not a hard dependency, but is also installed with qgis-full (which is
what you want if you want more optional dependencies - eg. for plugins - and is
also what the standalone installer is made from).
mathlib and nltk however are not in OSGeo4W.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20190920/68481fe6/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20190920/68481fe6/attachment.ksh>
More information about the osgeo4w-dev
