[osgeo4w-dev] QGIS failed to start because QT platform plugin
Pedro VenĂ¢ncio pedrongvenancio at gmail.com
Mon Aug 24 08:19:08 PDT 2020
Hi Jurgen,
> Did you install GRASS later?  If you installed it with QGIS it should have
> affected both QGIS w/ and w/o GRASS.  I guess .env for QGIS w/o GRASS was
> created clean because rbatch was not present yet.
I've installed all at the same time, because I've uninstalled and removed
everything from OSGeo4W64 to test. But maybe it's possible that during the
installation, QGIS w/o GRASS was installed, the GRASS and finally QGIS w/
GRASS?
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200824/d1941614/attachment.html>
More information about the osgeo4w-dev mailing list
