[osgeo4w-dev] gdal-3.0.3 or gdal-3.0.4 in OSGeo4W 64bit?
Helmut Kudrnovsky
hellik at web.de
Mon Feb 3 09:58:08 PST 2020
looking into my OSGeo4W 64bit setup installer and filtering for gdal, I see
that gdal-3.0.4-1 is installed in my OSGeo4W 64bit environment.
it is according the same as listed in
http://download.osgeo.org/osgeo4w/x86_64/release/gdal/ :
gdal-3.0.3-2-src.tar.bz2 6092 2020-Jan-24 22:11
gdal-3.0.3-2.tar.bz2 9M 2020-Jan-24 22:11
gdal-3.0.3-2.txt 18K 2020-Jan-24 21:34
gdal-3.0.4-1-src.tar.bz2 6101 2020-Jan-30 14:33
gdal-3.0.4-1.tar.bz2 9M 2020-Jan-30 14:33
gdal-3.0.4-1.txt 18K 2020-Jan-30 14:26
setup.hint 327 2020-Jan-30 14:26
opening the OSGeo4W shell:
run o-help for a list of available commands
C:\>gdalinfo --version
GDAL 3.0.3, released 2020/01/08
C:\>ogrinfo --version
C:\>
should gdal-3.0.4-1 in the actual or in the experimental mode? normally I
don't have activated the experimental mode in the OSGeo4W 64bit setup
installer.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/osgeo4w-dev-OSGeo-Win32-Installer-List-f3765018.html
More information about the osgeo4w-dev
