[osgeo4w-dev] [osgeo4w-setup-x86_64][Question] CLI is skipping the parameters?
João Gaspar
joao.f.r.gaspar at gmail.com
Fri Feb 28 07:04:22 PST 2020
So let me do an update.
I remove the fresh installation and package and the script run as expected
with the following behaviours:
Show me a dialogue only with downloading the packages and close after
download but the following packages aren't downloaded:
"gdal-oracle"
"gdal-mrsid"
"gdal-ecw"
"gdal-mss"
"gdal-filegdb"
"grass"
"saga-ltr"
But if I open using setup GUI with the same mirror I can see the packages
and I can download. For gdal "extensions" I probably point for some kind of
issue with the flag --auto-accept but involve grass and saga-ltr...
I will wait for some feedback.
Regards,
João
João Gaspar <joao.f.r.gaspar at gmail.com> escreveu no dia sexta, 28/02/2020
à(s) 14:07:
> Hi Devs,
> I'm working a PowerShell script using OSGeo4W Network Installer to
> download specific packages in quiet-mode from a mirror and save locally.
> What is happening is that we run but don't respect the parameter
> --quiet-mode, --no-desktop and don't download the specific packages. Only
> download the installer and the setup.ini
> This script is based on this gist:
> https://gist.github.com/Guts/6303dc5eb941eb24be3e27609cd46985
> and I'm following the https://trac.osgeo.org/osgeo4w/wiki/CommandLine
> Additional notes:
> OS: Windows 10 Professional
> I'm testing as Administrator.
> Test with and without quotes (URL, packages) and the behaviour is the same.
> I did the same install but with dialogs and the same packages and
> everything go right.
> My changed script is actually like this:
> # Save current working directory
> $starter_path = Get-Location
> # Move into the user download directory
> Set-Location -Path "$env:USERPROFILE/Downloads"
> # Download installer (storage standard installer)
> Write-Host "= Start downloading the OSGeo4W installer" -ForegroundColor
> Yellow
> Invoke-WebRequest -Uri "
> https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe" -OutFile
> "osgeo4w-setup-x86_64.exe"
> # Download the packages included into the QGIS LTR Specific packages
> Write-Host "== Installer downloaded into $env:USERPROFILE/Downloads"
> -ForegroundColor Yellow
> Write-Host "== Start downloading the QGIS LTR " -ForegroundColor Yellow
> .\osgeo4w-setup-x86_64.exe --quiet-mode --download --site "
> http://download.osgeo.org/osgeo4w" --no-desktop --advanced --arch x86_64
> --autoaccept --packages "qgis-ltr" "qgis-ltr-grass-plugin7"
> "qgis-ltr-oracle-provider" "gdal-oracle" "gdal-mrsid" "gdal-ecw" "gdal-mss"
> "gdal-filegdb" "hdf4" "hdf5" "libmysql" "netcdf" "oci" "opencl" "grass"
> "saga-ltr" "otb-bin" "otb-ice" "otb-python" "python3-exifread"
> "python3-h5py" "python3-pip" "python3-plotly" "python3-scipy"
> "python3-numpy" "python3-matplotlib" "python3-pyopengl" "python3-pyodbc"
> "ffmpeg" | out-null
> Did I do something wrong?
> Best regards,
> João Gaspar
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200228/3e8ca647/attachment.html>
More information about the osgeo4w-dev
