[osgeo4w-dev] [osgeo4w] #637: QGIS with GRASS Windows menu links are missing with OSGeo4W Installer
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jul 8 12:22:38 PDT 2020
Reporter:  Calvin  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Installer
 Version:          |  Resolution:
Keywords:          |
Comment (by jef):
 Not reproducable - and the standalone is build from osgeo4w packages and
 the shortcuts are created with the same scripts.  Did you install the
 {{{qgis-grass-plugin7}}} or {{{qgis-ltr-grass-plugin7}}} package?
 Check the {{{%OSGEO4W_ROOT%\var\log\setup.log}}} and
 {{{%OSGEO4W_ROOT%\var\log\setup.log.full}}} for errors.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/637#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
