[osgeo4w-dev] Wrong GDAL VersionInfo
Pedro VenĂ¢ncio
pedrongvenancio at gmail.com
Thu May 7 16:30:01 PDT 2020
Hi all,
I'm seeing that gdal 3.2.0dev is giving a wrong gdal.VersionInfo() output
with OSGeo4W:
import gdal
gdal.VersionInfo()
'3000400'
I opened this issue in GDAL mailing list and Even suggested to check if I
had intalled the python3-gdal-dev package and, in fact, python3-gdal-dev
was not installed.
First question is, should it not be installed by default with gdal-dev?
After installed the package and run gdal-dev-py3-env to set the appropriate
environment, version became correct in OSGeo4W Shell
gdal.VersionInfo()
'3020000'
However, I was trying it inside QGIS, in Python console, and there the
output is still '3000400', both in qgis-rel-dev (3.12.2) and qgis-dev
(3.13.0-master), compiled against GDAL 3.2.0dev.
I tried to change in qgis-rel-dev-g7.bat
from
call gdal-dev-env.bat
to
call gdal-dev-py3-env.bat
but without success. It seems that something more needs to be changed. Any
hint?
Thank you very much!
Best regards,
Pedro VenĂ¢ncio
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200508/3617e86e/attachment.html>
More information about the osgeo4w-dev
