[osgeo4w-dev] [osgeo4w-setup-x86_64][Question] CLI is skipping the parameters?
João Gaspar
joao.f.r.gaspar at gmail.com
Thu May 21 09:05:20 PDT 2020
Hi Stefan,
sorry for my late answer. Works like a charm.
Thank you.
Best regards,
João Gaspar
João Gaspar <joao.f.r.gaspar at gmail.com> escreveu no dia terça, 3/03/2020
à(s) 08:36:
> Hi Stefan,
> thank you for your email. I will test your way.
> Regards,
> João
> Stefan Blumentrath <Stefan.Blumentrath at nina.no> escreveu no dia segunda,
> 2/03/2020 à(s) 08:23:
>> Hi Joao,
>> This is how I use to download and create a local installation repo:
>> osgeo4w-setup-x86_64 -q -a x86_64 -g -k -S -l
>> "R:\\Program\\QGIS-OSGeo4W\\QGIS3_packages" -D -P avce00 -P boost -P
>> boost-devel -P boost-libs -P cairo -P curl -P eigen -P expat -P ffmpeg -P
>> fftw -P flann -P fltk -P freeglut -P freetype-devel -P freetype-vc-devel -P
>> freexl -P fribidi -P gdal -P gdal-ecw -P gdal-filegdb -P gdal-mrsid -P
>> gdal-mss -P gdal-oracle -P gdal-python -P gdal-sosi -P geos -P glew -P
>> glext -P glfw -P gpsbabel -P gpsbabelfe -P grass -P gs -P gsl-devel -P
>> gsl-libs -P hdf4 -P hdf5 -P hexer -P iconv -P iconv-vc14-devel -P icu-devel
>> -P itk -P java -P laszip -P libcairo -P libgeotiff -P libjpeg -P libjpeg12
>> -P libkml -P liblas -P …..
>> And then to install:
>> osgeo4w-setup-x86_64.exe -q -k -g -A -d -a x86_64 --local-install --root
>> "C:\\Programs\\OSGeo4W" -l "R:\\Program\\QGIS-OSGeo4W\\QGIS3_packages" -C
>> Libs -C Commandline_Utilities -C Desktop
>> Hope that helps a bit.
>> Cheers
>> Stefan
>> *From:* osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> *On Behalf Of *João
>> Gaspar
>> *Sent:* fredag 28. februar 2020 16:04
>> *To:* osgeo4w-dev at lists.osgeo.org
>> *Subject:* Re: [osgeo4w-dev] [osgeo4w-setup-x86_64][Question] CLI is
>> So let me do an update.
>> I remove the fresh installation and package and the script run as
>> expected with the following behaviours:
>> Show me a dialogue only with downloading the packages and close after
>> download but the following packages aren't downloaded:
>> "gdal-oracle"
>> "gdal-mrsid"
>> "gdal-ecw"
>> "gdal-mss"
>> "gdal-filegdb"
>> "grass"
>> "saga-ltr"
>> But if I open using setup GUI with the same mirror I can see the packages
>> and I can download. For gdal "extensions" I probably point for some kind of
>> issue with the flag --auto-accept but involve grass and saga-ltr...
>> I will wait for some feedback.
>> Regards,
>> João
>> João Gaspar <joao.f.r.gaspar at gmail.com> escreveu no dia sexta,
>> 28/02/2020 à(s) 14:07:
>> Hi Devs,
>> I'm working a PowerShell script using OSGeo4W Network Installer to
>> download specific packages in quiet-mode from a mirror and save locally.
>> What is happening is that we run but don't respect the parameter
>> --quiet-mode, --no-desktop and don't download the specific packages. Only
>> download the installer and the setup.ini
>> This script is based on this gist:
>> https://gist.github.com/Guts/6303dc5eb941eb24be3e27609cd46985
>> and I'm following the https://trac.osgeo.org/osgeo4w/wiki/CommandLine
>> Additional notes:
>> OS: Windows 10 Professional
>> I'm testing as Administrator.
>> Test with and without quotes (URL, packages) and the behaviour is the
>> same.
>> I did the same install but with dialogs and the same packages and
>> everything go right.
>> My changed script is actually like this:
>> # Save current working directory
>> $starter_path = Get-Location
>> # Move into the user download directory
>> Set-Location -Path "$env:USERPROFILE/Downloads"
>> # Download installer (storage standard installer)
>> Write-Host "= Start downloading the OSGeo4W installer" -ForegroundColor
>> Yellow
>> Invoke-WebRequest -Uri "
>> https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe" -OutFile
>> "osgeo4w-setup-x86_64.exe"
>> # Download the packages included into the QGIS LTR Specific packages
>> Write-Host "== Installer downloaded into $env:USERPROFILE/Downloads"
>> -ForegroundColor Yellow
>> Write-Host "== Start downloading the QGIS LTR " -ForegroundColor Yellow
>> .\osgeo4w-setup-x86_64.exe --quiet-mode --download --site "
>> http://download.osgeo.org/osgeo4w" --no-desktop --advanced --arch x86_64
>> --autoaccept --packages "qgis-ltr" "qgis-ltr-grass-plugin7"
>> "qgis-ltr-oracle-provider" "gdal-oracle" "gdal-mrsid" "gdal-ecw" "gdal-mss"
>> "gdal-filegdb" "hdf4" "hdf5" "libmysql" "netcdf" "oci" "opencl" "grass"
>> "saga-ltr" "otb-bin" "otb-ice" "otb-python" "python3-exifread"
>> "python3-h5py" "python3-pip" "python3-plotly" "python3-scipy"
>> "python3-numpy" "python3-matplotlib" "python3-pyopengl" "python3-pyodbc"
>> "ffmpeg" | out-null
>> Did I do something wrong?
>> Best regards,
>> João Gaspar
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200521/c9e77433/attachment.html>
More information about the osgeo4w-dev
