[osgeo4w-dev] Please Help!
Lourens van Zyl lourens at terragis.co.za
Tue Nov 10 13:53:04 PST 2020
To Whom it may concern
I am hoping one of you might be able to assist me.
I get satellite images from Eumetsat in NetCDF format, which I need to
convert to GeoTiff or similar to be able to use it in GIS packages such as
QGIS.
I usually make use of GDALWARP within OSGeo4W Shell.
This is what the data should look like (as viewed within Panoply software
from NASA):
QGIS cannot extract the lat/long values from the file, so if you open a
NetCDF file in QGIS it is not georeferenced.
That is why I use GDAL within OSGeo4W Shell.
I used to use the above command in OSGeo4W Shell with great success in the
past.
But now I get the following error:
I decided to try a file that I was able to convert in the past (March/April
2020), But ran int the same error
So I decided to uninstall QGIS 3.16 and install an older version.
But now get this error:
Please can you help me to convert my NetCDF files to something I can use in
GIS.
I will send you a sample NetCDF file with WeTransfer. I am specifically
interested in Ch4: IR3.9.
Your help is appreciated in advance
Kind regards
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20201110/69e42d90/attachment-0011.png>
More information about the osgeo4w-dev mailing list
