[osgeo4w-dev] [osgeo4w] #678: Bug in libjpeg used by gdalinfo in testing OSGeo4W Shell
OSGeo4W trac_osgeo4w at osgeo.org
Fri Apr 2 11:46:00 PDT 2021
Reporter:  Calvin  |      Owner:  osgeo4w-dev@…
    Type:  defect  |     Status:  new
Priority:  major   |  Component:  Installer
 Version:          |   Keywords:
 This is for the installer
 http://download.osgeo.org/osgeo4w/testing/osgeo4w-setup.exe
 While importing some geotagged images into QGIS I found one that failed.
 When I go to the OSGeo4W Shell and type "gdalinfo dam.jpg" I get the error
 message.
 ERROR 1: libjpeg: Bogus marker length
 gdalinfo failed - unable to open 'dam.jpg'.
 Other JPEG images work fine.
 If I use the regular OSGeo4W installer I get the normal gdalinfo reporting
 when I run "gdalinfo dam.jpg".
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/678>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
