[osgeo4w-dev] [osgeo4w] #659: Qt Designer for dev and nightly build fails to load the QGIS custom widgets
trac_osgeo4w at osgeo.org
Tue Feb 16 02:53:03 PST 2021
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
Installing qgis-dev via OSGeo4W and launching the Qt Designer using the
"Qt Designer with QGIS 3.17.0 custom widgets (Nightly)" the QGIS custom
widgets are not available and the following error is present in
Help->About Plugins:
Cannot load library C:\OSGEO4~2\apps\qgis-
dev\qtplugins\designer\qgis_customwidgets.dll: The specified module could
not be found
As a workaround, changing in qgis-dev-designer.bat the following line:
call py3_env.bat
with:
call gdal-dev-py3-env.bat
fixes the issue.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/659>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
