[osgeo4w-dev] [osgeo4w] #656: Missing DLL when importing Fiona, Geopandas or rasterio within QGIS
OSGeo4W trac_osgeo4w at osgeo.org
Sun Jan 10 19:27:39 PST 2021
Reporter:  cratcliff  |      Owner:  osgeo4w-dev@…
    Type:  defect     |     Status:  new
Priority:  major      |  Component:  Package
 Version:             |   Keywords:  fiona geopanda rasterio
 Since the release of **QGIS 3.16.2-Hannover** or **3.10.13-A Coruña** on
 Windows 10 I have been getting errors (see below) when trying to import
 fiona, geopandas and rasterio.
 I have installed fiona, geopandas and rasterio using the OSGeo4w.
 How do I go about fixing this issue for this release while not breaking
 older releases?
 Is there a way to configure these packages to work with QGIS without
 having to request a rebuild/fix every time a new version of QGIS is
 released?
 Thanks in Advance.
 Christina
 import geopandas
   File "C:\PROGRA~1\QGIS3~1.16\apps\Python37\lib\code.py", line 90, in
 runcode
     exec(code, self.locals)
   File "<input>", line 1, in <module>
   File "C:/PROGRA~1/QGIS3~1.16/apps/qgis/./python\qgis\utils.py", line
 792, in _import
     mod = _builtin_import(name, globals, locals, fromlist, level)
   File "C:\PROGRA~1\QGIS3~1.16\apps\Python37\lib\site-
 packages\geopandas\__init__.py", line 5, in <module>
     from geopandas.io.file import read_file  # noqa
 792, in _import
 packages\geopandas\io\file.py", line 6, in <module>
     import fiona
 792, in _import
 packages\fiona\__init__.py", line 84, in <module>
     from fiona.collection import BytesCollection, Collection
 792, in _import
 packages\fiona\collection.py", line 9, in <module>
     from fiona.ogrext import Iterator, ItemsIterator, KeysIterator
 792, in _import
 ImportError: DLL load failed: The specified module could not be found.
 import rasterio
 runcode
 792, in _import
 packages\rasterio\__init__.py", line 22, in <module>
     from rasterio._base import gdal_version
 792, in _import
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/656>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
