[osgeo4w-dev] [osgeo4w] #657: GRASS 7 plugin not working: 3.10.13-2, 3.16.2-2 standalone installers and OSGeo4W network installer
trac_osgeo4w at osgeo.org
Tue Jan 12 23:00:43 PST 2021
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Keywords:
Using QGIS installed via 3.10.13-2, 3.16.2-2 standalone installers or via
OSGeo4W network installer, is it not possible to use the GRASS7 plugin in
QGIS.
The following error is reported in the Log Messages panel:
WARNING GRASS init error : Problem in GRASS
initialization, GRASS provider and plugin will not work : Module built
against version d8fbd49af but trying to use version 2b6ab2893. You need to
rebuild GRASS GIS or untangle multiple installations.
Moreover, a wrong "QGIS Desktop 3.16.2 with GRASS 7.8.4" shortcut is
created in the Windows Starts menu, instead of a "QGIS Desktop 3.16.2 with
GRASS 7.8.5".
So I think the qgis-grass-plugin7-3.16.2 and qgis-ltr-grass-
plugin7-3.10.13 plugins should be rebuild against GRASS 7.8.5.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/657>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
