[osgeo4w-dev] [osgeo4w] #682: MSI and EXE installers: different Python locale settings leads to issues with the Python console script editor
OSGeo4W trac_osgeo4w at osgeo.org
Tue Jun 22 10:58:26 PDT 2021
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:               |
Comment (by andreaerdna):
 Yes, most likely this is the same underlying reason that causes also the
 issue you reported, too.
 Probably also the issue fixed by https://github.com/qgis/QGIS/pull/43249
 was due to the same reason.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/682#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
