[osgeo4w-dev] [osgeo4w] #681: no-shortcuts options not working
OSGeo4W trac_osgeo4w at osgeo.org
Mon May 17 08:06:02 PDT 2021
Reporter:  rhaubourg  |       Owner:  osgeo4w-dev@…
    Type:  defect     |      Status:  new
Priority:  minor      |   Component:  Package
 Version:             |  Resolution:
Keywords:             |
Changes (by jef):
 * priority:  major => minor
Old description:
> Hi there,
> running
> .\osgeo4w-setup.exe --quiet-mode --root "X:\OSGEO4W_DEPLOY_TEST\INSTALL"
> --local-install --local-package-dir
> "X:\OSGEO4W_DEPLOY_LOCAL\PAQUETS\http%3a%2f%2fwww.norbit.de%2fosgeo4w%2f"
> --autoaccept  --no-shortcuts --delete-orphans --upgrade-also  -C Libs -C
> Commandline_Utilities -C Desktop
> still creates a menu with the directory name  "OSGEO4W_DEPLOY_LOCAL"
> I also tested with --no-starmenu and --no-desktop, but the shortcut
> entries are still created
New description:
 Hi there,
 running
 I also tested with --no-startmenu and --no-desktop, but the shortcut
Comment:
 The shortcuts are created by the packages - each package has to respect
 the setting of OSGEO4W_DESKTOP_LINKS / OSGEO4W_MENU_LINKS and place the
 shortcut into and OSGEO4W_DESKTOP / OSGEO4W_STARTMENU.   Which don't?  I
 suppose GRASS or very old ones.  In testing that cruft is probably gone.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/681#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
