[osgeo4w-dev] [osgeo4w] #702: Blank output with OSGeo4W's GDAL 3.3.1 build
trac_osgeo4w at osgeo.org
Tue Nov 9 04:00:31 PST 2021
Reporter: philiusmaximus | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: GDAL pdf Georeferencer QGIS |
Description changed by jef:
Old description:
> I'm working int he latest version of QGIS and I need to georeference a
> pdf.
> Georeferencer opens all .pdf files but some are not visible; they appear
> white with no image detail.
> This does not occur on all .pdf files.
> I have tried different QGIS profiles and created a new one (this does
> not fix the bug)
> I have tried printing the document to pdf and opening the print (that
> does not fix the bug)
> The .pdf file is not layered, has no markups, special features, that
> I can see (using Foxit)
> This was going wrong for me on 3.16.7 so I updated to 3.16.11 (this
> did not fix the bug)
> I have uninstalled all my third party plugins and tried (this does
> not fix the bug)
> Same file opens successfully in 3.10.4 (randomly chose an older
> version where I knew it worked)
> I can open the pdf successfully on an older version of QGIS with an older
> version of GDAl and that works fine.
> Up until now I have been able to take screenshots of the pdf files that
> have this error and geocode those instead, but I will be trying to
> geocode some large plans soon and I don't think screenshots will suffice.
> I have attached the pdf that I opened in the screenshot examples.
> Further information can be found on the QGIS forum
> ([https://github.com/qgis/QGIS/issues/45657]) and the GDAL forum
> ([https://github.com/OSGeo/gdal/issues/4701]) where I have orginally
> posted this bug. There is information and analysis there from folks.
> I have tried to attach files but they are too large to attach. Please see
> the QGIS and GDAL posts for the document and screenshots.
> Also, apologies if any of the settings (Type, Priority, etc.) are
> incorrect - first timer here, please feel free to edit.
> If you need any further info that I can provide, please do let me know.
> Many thanks in advance!
New description:
pdf.
not fix the bug)
The .pdf file is not layered, has no markups, special features, that I
I have uninstalled all my third party plugins and tried (this does not
fix the bug)
have this error and geocode those instead, but I will be trying to geocode
Further information can be found on the QGIS issues
([https://github.com/qgis/QGIS/issues/45657]) and the GDAL issues
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/702#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
