[osgeo4w-dev] [osgeo4w] #705: GRASS 7 plugin not working with QGIS 3.22.0 (Module built against version ... but trying to use version ...)
OSGeo4W trac_osgeo4w at osgeo.org
Thu Nov 11 03:49:09 PST 2021
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:
 Using QGIS 3.22.0 installed via the OSGeo4W v2 Network Installer (qgis
 3.22.0-4) or the Standalone Installer (QGIS-OSGeo4W-3.22.0-3.msi), it is
 not possible to use the GRASS7 plugin (qgis-grass-plugin 3.22.0-4, grass
 7.8.6-6).
 The following error is reported in the Log Messages panel:
 2021-11-11T11:36:45     WARNING    GRASS init error : Problem in GRASS
 initialization, GRASS provider and plugin will not work : Module built
 against version 2021-10-11T09:56:15+00:00 but trying to use version
 2021-11-01T10:26:16+00:00. You need to rebuild GRASS GIS or untangle
 multiple installations.
 The issue doesn't occur with QGIS 3.16.13 from OSGeo4W v2 (qgis-ltr
 3.16.13-1, qgis-ltr-grass-plugin 3.16.13-1, grass 7.8.6-6)  and with QGIS
 3.23.0-master (qgis-dev 3.23.0-124-a119884d35-1).
 See also https://lists.osgeo.org/pipermail/qgis-
 user/2021-November/050159.html
 See previous similar issues https://trac.osgeo.org/osgeo4w/ticket/695 and
 https://trac.osgeo.org/osgeo4w/ticket/657
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/705>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
