[osgeo4w-dev] [osgeo4w] #695: GRASS 7 plugin issue installing QGIS and QGIS LTR via OSGeo4W v2 network installer
OSGeo4W trac_osgeo4w at osgeo.org
Thu Oct 14 03:34:18 PDT 2021
installer
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:
 Using QGIS and QGIS LTR installed via OSGeo4W v2 Network Installer, is it
 not possible to use the GRASS7 plugin in QGIS. The following error is
 reported in the Log Messages panel:
 WARNING    GRASS init error : Problem in GRASS initialization, GRASS
 provider and plugin will not work : Module built against version
 2021-08-12T15:48:18+00:00 but trying to use version
 2021-10-11T09:56:15+00:00. You need to rebuild GRASS GIS or untangle
 multiple installations.
 So I think the qgis-grass-plugin-3.20.3 and qgis-ltr-grass-plugin-3.16.11
 plugins should be rebuild against the latest GRASS package available
 grass-7.8.6.
 They are instead built against the grass-7.8.6RC2-1 package which is not
 currently possible to install through the OSGeo4W v2 Network Installer.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/695>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
