[osgeo4w-dev] [osgeo4w] #738: grass8 needs proj82-runtime
trac_osgeo4w at osgeo.org
Fri Apr 29 10:05:17 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
Installing GRASS 8 (grass8 8.0.1-2), without also installing QGIS, leads
to the following error unsuccessfully trying to launch it:
Sto avviando GRASS GIS...
ATTENZIONE: Il locking concorrente del mapset non è supportato in Windows.
Eliminando i file temporanei...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Benvenuto in GRASS GIS8.0.1
Homepage di GRASS GIS: https://grass.osgeo.org
Questa versione è eseguita tramite: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
VIsualizza i termini di licenza con: g.version -c
See citation options with: g.version -x
Se necessario, riavvia la GUI con: g.gui wxpython
Per uscire digitare: exit
Sto avviando <wxpython> GUI in background, attendere prego...
Microsoft Windows [Versione 10.0.18362.778]
(c) 2019 Microsoft Corporation. Tutti i diritti sono riservati.
C:\Users\giudiceandrea\Documents>wxnviz.py: Could not load grass_g3d.8.0.
wxdigit.py: Could not load grass_vector.8.0.
File "C:\OSC726~1\apps\Python39\lib\site-packages\wx\core.py", line
3407, in <lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\wxgui.py", line 88, in
show_main_gui
mainframe = GMFrame(parent=None, id=wx.ID_ANY,
workspace=self.workspaceFile)
File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\lmgr\frame.py", line
156, in __init__
self._createConsole(self.notebook)
379, in _createConsole
self.goutput = GConsoleWindow(
File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\gui_core\goutput.py",
line 127, in __init__
self.cmdPrompt = GPromptSTC(
File "C:\OSC726~1\apps\grass\grass80\gui\wxpython\gui_core\prompt.py",
line 155, in __init__
GPrompt.__init__(self, parent=parent, giface=giface,
menuModel=menuModel)
line 57, in __init__
self.mapList = self._getListOfMaps()
line 114, in _getListOfMaps
result["raster"] = grass.list_strings("raster")
File "C:\OSC726~1\apps\grass\grass80\etc\python\grass\script\core.py",
line 1462, in list_strings
for line in read_command(
line 606, in read_command
return handle_errors(returncode, stdout, args, kwargs)
line 429, in handle_errors
raise CalledModuleError(module=module, code=code,
returncode=returncode)
grass.exceptions.CalledModuleError: Module run `g.list --q -m type=raster`
ended with an error.
The subprocess ended with a non-zero return code: 3221225781. See errors
above the traceback or in the error output.
It seems to me this is due to the the fact that the package proj82-runtime
is not listed in the grass8 dependencies, while proj_8_2.dll is needed by
libgrass_gproj.8.0.dll.
Manually installing proj82-runtime fixes the issue and then it is possible
to successfully launch GRASS 8.
When qgis* is installed alongside grass8, then the issue doesn't occur
because proj82-runtime is automatically installed as a dependency of
python3-pyproj (why pyproj needs PROJ 8 and not PROJ 9?) which in turns is
automatically installed as a dependency of qgis*.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/738>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
