[osgeo4w-dev] [osgeo4w] #758: Crash when reading SNAPPY compressed Parquet files through GDAL
OSGeo4W trac_osgeo4w at osgeo.org
Mon Aug 1 07:25:57 PDT 2022
Reporter:  rouault  |       Owner:  osgeo4w-dev@…
    Type:  defect   |      Status:  new
Priority:  major    |   Component:  Package
 Version:           |  Resolution:
Keywords:           |
Comment (by andreaerdna):
 Replying to [comment:5 jef]:
 > Replying to [comment:4 andreaerdna]:
 > > CPU-Z reports the following instructions sets for AMD A8-6410: MMX
 (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES,
 AVX
 > Does setting the environment variable ARROW_USER_SIMD_LEVEL to NONE make
 a difference on your machine?
 No difference with {{{set ARROW_USER_SIMD_LEVEL=NONE}}} and also with any
 other value specified at
 https://arrow.apache.org/docs/dev/cpp/env_vars.html#envvar-
 ARROW_USER_SIMD_LEVEL (apart from "SSE4.2" which should be actually
 "SSE4_2").
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/758#comment:6>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
