[osgeo4w-dev] [osgeo4w] #759: qgis-dev 3.27.0-Master crashes during startup in some circumstances
trac_osgeo4w at osgeo.org
Wed Aug 3 01:59:47 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: major | Component: Package
Version: | Keywords:
QGIS 3.27.0-Master (qgis-dev-3.27.0-286-fc5faa84bf-1) crashes on startup
(during "Setting up the GUI"), when launched from the shortcut link "QGIS
Desktop 3.27.0 (Nigthly)" in the start menu, if there is a file or a
folder with the name containing non-ASCII characters (like e.g. è, é, æ,
ø, å, ...) in the user "Documents" directory.
Note that the QGIS shortcut links in the start menu contain the user
"Documents" folder path in the "Start in" property.
QGIS 3.26.1 and QGIS 3.22.9 in the same OSGeo4W installation don't suffer
from such issue.
See https://github.com/qgis/QGIS/issues/49507 (and probably also
https://github.com/qgis/QGIS/issues/49546).
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/759>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
