[osgeo4w-dev] [osgeo4w] #465: Add gdal-grass plugin to OSGeo4W
trac_osgeo4w at osgeo.org
Wed Jun 22 01:28:15 PDT 2022
Reporter: sbl | Owner: osgeo4w-dev@…
Type: enhancement | Status: new
Priority: major | Component: Package
Version: | Resolution:
Keywords: gdal,grass |
Comment (by jef):
Replying to [comment:2 sbl]:
> It could be integrated into the GRASS package, I guess.
> Recently, the plugin code was separated out into it`s own repo:
https://github.com/OSGeo/gdal-grass
Sure. That's why I ask.
> From what I understand, devs there dealt with potential circle
dependencies of the plugin. So, it should be OK to build separately, but
if you prefer it to be part of the GRASS package(s) I could have a look at
than...
Yes, GRASS needs GDAL to build and GDAL needed GRASS to build the driver.
So you couldn't fully build either package and had to first build GDAL
without the driver, GRASS with the GDAL w/o driver and then GDAL with the
driver.
Now that the driver is separate you can fully build GDAL, GRASS and then
driver. I guess the driver should be rebuilt with (each package of) GRASS
anyway, so having it in the GRASS package could be beneficial.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/465#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
