[osgeo4w-dev] [osgeo4w] #715: ssl.SSLError: A failure in the SSL library occurred (_ssl.c:1129)
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 02:09:47 PDT 2022
Reporter:  andreaerdna  |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  closed
Priority:  major        |   Component:  Package
 Version:               |  Resolution:  fixed
Keywords:               |
Comment (by jef):
 Odd:
 import os
 import ssl
 import socket
 import urllib.request
 print(f"SSL_CERT_FILE:{os.getenv('SSL_CERT_FILE')}")
 for i in ['www.osgeo.org', 'www.python.org']:
   try:
     socketHandler = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
     socketWrapped =
 ssl.create_default_context().wrap_socket(socketHandler, server_hostname=i)
     socketWrapped.connect((i, 443))
     print(f"ssl {i}: OK")
   except Exception as e:
     print(f"ssl {i}: FAIL {e}")
   try:
     response = urllib.request.urlopen(f'https://{i}/')
     html = response.read()
     print(f"urllib {i}: OK")
     print(f"urllib {i}: FAIL {e}")
 python console, 3.24.2, Windows Sandbox (Windows 10 Version 2004),
 shortcut:
 SSL_CERT_FILE:None
 ssl www.osgeo.org: OK
 urllib www.osgeo.org: OK
 ssl www.python.org: FAIL A failure in the SSL library occurred
 (_ssl.c:1129)
 urllib www.python.org: FAIL <urlopen error A failure in the SSL library
 occurred (_ssl.c:1129)>
 qgis.bat:
 SSL_CERT_FILE:C:\OSGeo4W\bin\curl-ca-bundle.crt
 ssl www.python.org: OK
 urllib www.python.org: OK
 python console, 3.24.2, Windows 10 Version 2009, qgis.bat:
 SSL_CERT_FILE:D:\TEMP\OSC26D~1\bin\curl-ca-bundle.crt
 python console, 3.24.2, Windows 10 Version 2009, shortcut:
 SSL_CERT_FILE:None
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/715#comment:17>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
