[osgeo4w-dev] [osgeo4w] #739: LERC codec once again missing in GDAL 3.5.0dev/QGISdev 3.25-230
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 5 15:11:39 PDT 2022
Reporter:  houska1  |      Owner:  osgeo4w-dev@…
    Type:  defect   |     Status:  new
Priority:  major    |  Component:  Package
 Version:           |   Keywords:  gdal libtiff lerc
 Latest QGISdev and its embedded GDAL will once again not read LERC-encoded
 TIFFs. Same issue as https://trac.osgeo.org/osgeo4w/ticket/679 and
 https://trac.osgeo.org/osgeo4w/ticket/663, presumably. For whatever
 reason, the fix done there does not seem to be sticky.
 GDALdev through -229 was OK; I believe it used a GDAL 3.4.? build.
 Latest QGIS 3.24.2-2 with GDAL 3.4.3 is also fine.
 Thanks!
 (Calling it major since though one can work around it, it does break stuff
 that worked before.)
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/739>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
