[osgeo4w-dev] [osgeo4w] #743: GRASS 8 plugin not available in QGIS Desktop 3.25.0 (Nigthly)
OSGeo4W trac_osgeo4w at osgeo.org
Tue May 10 02:10:34 PDT 2022
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  major        |  Component:  Package
 Version:               |   Keywords:
 With the latest grass8 8.0.1-3 and qgis-dev* 3.25.0-233-383b2f9f78-1, the
 GRASS 8 plugin is not available in QGIS Desktop 3.25.0 (Nigthly) and the
 following errors are reported in the Log Messages panel:
 2022-05-10T08:53:45     WARNING    Failed to load C:/OSA194~1/apps/qgis-
 dev/plugins/plugin_grass8.dll (Reason: Cannot load library
 C:\OSA194~1\apps\qgis-dev\plugins\plugin_grass8.dll: Impossibile trovare
 il modulo specificato.)
 dev/plugins/provider_grass8.dll (Reason: Cannot load library
 C:\OSA194~1\apps\qgis-dev\plugins\provider_grass8.dll: Impossibile trovare
 dev/plugins/provider_grassraster8.dll (Reason: Cannot load library
 C:\OSA194~1\apps\qgis-dev\plugins\provider_grassraster8.dll: Impossibile
 trovare il modulo specificato.)
 It seems to me this is due to the the fact that the package proj82-runtime
 is not listed in the grass8 dependencies, while proj_8_2.dll is needed by
 libgrass_gproj.8.0.dll.
 Manually installing proj82-runtime fixes the issue.
 The same underlying make impossible to launch GRASS GIS 8: see #738.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/743>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
