[osgeo4w-dev] [osgeo4w] #744: pyproj (python3-pyproj) not working in QGIS
trac_osgeo4w at osgeo.org
Tue May 10 04:13:17 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: invalid
Keywords: |
Comment (by andreaerdna):
With a fresh install of QGIS Desktop 3.22.4 (qgis-full 3.24.2-2) using
OSGeo4W, the python3-pyproj package is installed, the proj90-runtime
package is installed and the proj82-runtime package is not installed.
The following Python commands (from
https://pyproj4.github.io/pyproj/stable/examples.html) in the QGIS Python
console:
from pyproj import CRS
crs = CRS.from_epsg(4326)
generate the following error:
File "C:\OSA194~1\apps\Python39\lib\code.py", line 90, in runcode
exec(code, self.locals)
File "<input>", line 1, in <module>
File "C:\OSA194~1\apps\Python39\lib\site-packages\pyproj\crs\crs.py",
line 379, in from_epsg
return cls.from_user_input(_prepare_from_epsg(code))
line 488, in from_user_input
return cls(value, **kwargs)
line 335, in __init__
self._local.crs = _CRS(self.srs)
File "pyproj\_crs.pyx", line 2352, in pyproj._crs._CRS.__init__
pyproj.exceptions.CRSError: Invalid projection: epsg:4326: (Internal Proj
Error: proj_create: no database context specified)
After manually installing the proj82-runtime package, the same following
Python commands in the QGIS Python console:
doesn't generate any error message.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/744#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
