[osgeo4w-dev] [osgeo4w] #761: qgis-dev: ImportError: DLL load failed while importing _gdal
trac_osgeo4w at osgeo.org
Mon Sep 26 00:47:15 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: new
Priority: critical | Component: Package
Version: | Keywords:
The GDAL processing algorithms (e.g. GDAL Merge) with the latest QGIS
3.27.0-Master (qgis-dev 3.27.0-312-c6eca784ad-1 and gdal-dev
3.6.0-117-ebe17cf8fc-1) fail with the following error:
File "C:\OSFB9F~1\apps\gdal-dev\lib\site-packages\osgeo\__init__.py", line
30, in swig_import_helper
return importlib.import_module(mname)
File "C:\OSFB9F~1\apps\Python39\lib\importlib\__init__.py", line 127, in
import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 666, in _load_unlocked
File "<frozen importlib._bootstrap>", line 565, in module_from_spec
File "<frozen importlib._bootstrap_external>", line 1173, in create_module
File "<frozen importlib._bootstrap>", line 228, in
_call_with_frames_removed
ImportError: DLL load failed while importing _gdal: Impossibile trovare il
modulo specificato.
During handling of the above exception, another exception occurred:
File "C:\OSFB9F~1\apps\gdal-dev\Scripts\gdal_merge.py", line 5, in
<module>
from osgeo.gdal import deprecation_warn
46, in <module>
_gdal = swig_import_helper()
42, in swig_import_helper
raise ImportError(traceback_string + '\n' + msg)
ImportError: Traceback (most recent call last):
import_module
modulo specificato.
On Windows, with Python >= 3.8, DLLs are no longer imported from the PATH.
If gdalXXX.dll is in the PATH, then set the USE_PATH_FOR_GDAL_PYTHON=YES
environment variable
to feed the PATH into os.add_dll_directory().
Process returned error code 1
QGIS 3.22.11 and 3.26.3 in the same OSGeo4W installation are not affected.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/761>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
