[osgeo4w-dev] [osgeo4w] #761: gdal-dev: ImportError: DLL load failed while importing _gdal
trac_osgeo4w at osgeo.org
Tue Sep 27 01:57:19 PDT 2022
Reporter: andreaerdna | Owner: osgeo4w-dev@…
Type: defect | Status: closed
Priority: critical | Component: Package
Version: | Resolution: fixed
Keywords: |
Comment (by andreaerdna):
It seems adding
call "%OSGEO4W_ROOT%\bin\gdal-dev-env.bat"
in %OSGEO4W_ROOT%\apps\gdal-dev\Scripts\gdal_merge.bat
fixes the issue for GDAL Merge processing algorithm.
gdal_merge.bat:
@echo off
call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
python "%OSGEO4W_ROOT%\apps\gdal-dev\Scripts\gdal_merge.py" %*
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/761#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
