[osgeo4w-dev] [osgeo4w] #775: Dependency issue
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 10 03:33:33 PST 2023
Reporter:  gpsaliola  |      Owner:  osgeo4w-dev@…
    Type:  defect     |     Status:  new
Priority:  major      |  Component:  Installer
 Version:             |   Keywords:  osgeo4w setup EPSG
 I've installed only command line utilities with this command:
 "osgeo4w-setup.exe -q -A -a x86_64 -k -L -d -n -N -D -s
 https://download.osgeo.org/osgeo4w/v2 -C Commandline_Utilities -P
 gpsbabel-gui"
 I have noticed that the commands behave as if the EPSG database has not
 been installed.
 If I manually add "-P proj82-runtime" (not installed by default) to the
 installation command, everything is ok.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/775>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
