[osgeo4w-dev] [osgeo4w] #775: Dependency issue
OSGeo4W trac_osgeo4w at osgeo.org
Sat Feb 11 11:18:32 PST 2023
Reporter:  gpsaliola           |       Owner:  osgeo4w-dev@…
    Type:  defect              |      Status:  closed
Priority:  major               |   Component:  Installer
 Version:                      |  Resolution:  invalid
Keywords:  osgeo4w setup EPSG  |
Changes (by jef):
 * status:  new => closed
 * resolution:   => invalid
Comment:
 -L implies that you downloaded all dependencies into you local package
 directory.  gdal depends on gdal306-runtime, which depends on
 proj91-runtime, which (like the outdated proj82-runtime you installed)
 depends on proj-data, which has the actual proj datafiles.  Your local
 package directory apparently didn't have proj-data, but proj91-runtime -
 otherwise gdalinfo wouldn't even have started.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/775#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
