[osgeo4w-dev] [osgeo4w] #796: qgis-common.bat exit code -1073741511
    trac_osgeo4w at osgeo.org
    Sun Jun 25 08:30:02 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Comment (by jef):
 Did you install 3.18 from OSGeo4W v1 or v2?  And if v1, did you try an
 upgrade to v2?  Could be that you're tried to upgrade from v1 to v2 and
 are now struggling with leftover from v1 installation - which is why
 upgrading from v1 to v2 is not supported.
 As for dependency walker: you should start it form the OSGeo4W shell. Your
 output doesn't matches the actual PATH with which crssync invoked.
 Try following
 https://github.com/qgis/QGIS/issues/26891#issuecomment-495889169 (likely
 that qgis for the same reasons).
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:11>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev
