[osgeo4w-dev] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jun 26 09:36:47 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Comment (by Antonio3Brandao):
 comment:10
 Hello andreaerdna, openjp2.dll is installed on the correct path. In fact
 there was two openjp2.dll in my PC. that's why the logs seems to be wrong.
 [[Image(https://i.imgur.com/3l87Kyz.png)]]
 In reference to the logs that I attach, I have to say that I had a
 software in my PC - XNView - that was in my windows environment with a
 openjp2.dll inside in the bin folder, and when QGIS install the
 application it uses that library in that folder instead the one on QGIS
 bin folder. That's why it seems that the logs were wrong. I had to read
 off of a second software because of another *.dll that were in conflict
 during installation of QGIS. After that I repair the visual c++
 redistributable package 2015 and everything was good. Until the next
 morning after start the PC again.
 See last logs in attachement.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:12>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
