[osgeo4w-dev] A load of updates in OSGeo4W
Andrea Giudiceandrea andreaerdna at libero.it
Mon Apr 15 11:31:33 PDT 2024
Il 15/04/2024 01:02, Jürgen E. Fischer via osgeo4w-dev ha scritto:
> I just uploaded an update to OSGeo4W.   It is basically a rebuild of everything
> with a newer compiler (Visual C++ 2022) and updates of almost all versions.
> The update should work cleanly and cause no visual changes.
Hi Jürgen,
I did a clean install of qgis-full 3.36.1-2 and qgis-ltr-full 3.34.5-2
packages and obtained the following "Postinstall script errors":
Package: qgis-common
	qgis-common.bat exit code -1073741511
Package: qgis-ltr-common
	qgis-ltr-common.bat exit code -1073741511
However, I don't see any issue starting QGIS 3.34.5 and 3.36.1 (apart
from https://github.com/qgis/QGIS/issues/57070).
Best regards.
Andrea
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20240415/3e7e3e20/attachment-0001.bin>
More information about the osgeo4w-dev mailing list
